Enable Automatic Reboot
Activates or disables automatic reboot on a fatal error. The default value is activated.
Important
Important
Do not change this parameter unless directed by technical support.
    enable
    configure terminal
  2. Enable automatic reboot:
    boot config flags reboot
  3. Save the changed configuration.
