This procedure only applies to the VSP 7400 Series.
Configure IP Shortcuts and layer 3 VSN on the Virtual Router Forwarding (VRF) instance.
Perform this procedure to configure IS-IS Multi-area SPB IPv4 unicast redistribution on a specific VRF instance on the switch.
Configuring IS-IS Multi-area SPB IPv4 unicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#isis multi-area ip redistribute unicast home-to-remote
Switch:1(router-vrf)#isis multi-area ip redistribute unicast home-to-remote route-map test
Switch:1(router-vrf)#isis multi-area ip redistribute unicast home-to-remote enable
Switch:1(router-vrf)#show isis multi-area ip redistribute unicast home-to-remote vrf VRF1
            ISIS Multiarea Redistribute List for ip unicast - VRF VRF1
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(router-vrf)#exit
Switch:1(config)#isis multi-area ip apply redistribute unicast home-to-remote vrf VRF1
The following table defines parameters for the isis multi-area ip redistribute unicast and the isis multi-area ip apply redistribute unicast commands.
| Variable | Value |
| enable |
                                 Enables IPv4 unicast redistribution on the VRF instance.  |
| home-to-remote |
                                 Specifies the IPv4 unicast redistribution configuration for home to remote direction.  |
| remote-to-home |
                                 Specifies the IPv4 unicast redistribution configuration for remote to home direction.  |
| route-map WORD<1-64> |
                                 Specifies the name of the route policy.  |
| vrf WORD<1-16> |
                                 Specifies the IPv4 unicast redistribution configuration for specific VRF instance.  |
