                                 Feature  |
                                 Product  |
                                 Release introduced  |
                                 Forward Error Correction (FEC) (configurable)  |
                                 VSP 4450 Series  |
                                 Not Applicable  |
                                 VSP 4900 Series  |
                                 VOSS 8.1 VIM5-4YE at 25 Gbps  |
                                 VSP 7200 Series  |
                                 Not Applicable  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 Not Supported  |
                                 VSP 8400 Series  |
                                 VOSS 8.0  |
                                 VSP 8600 Series  |
                                 VSP 8600 6.2  |
                                 XA1400 Series  |
                                 Not Applicable  |
Forward Error Correction (FEC) is a method of obtaining error control in data transmission over an unreliable or noisy channel in which the source (transmitter) encodes the data in a redundant way by using an error correcting code (ECC). This redundancy enables a destination (receiver) to detect a limited number of errors and correct them without requiring a re-transmission.
FEC is useful where re-transmitting data is either expensive or impossible, for example, when transmitting to multiple receivers in multicast. However, although FEC provides more error control, it introduces a latency in data transmission.
You typically configure FEC on a port. The supported options are:
cl91 (Clause 91 RS-FEC)
cl108 (Clause 108 RS-FEC):
cl74 (Clause 74 Firecode R-FEC):
auto:
FEC is not supported on:
Out-of-band (OOB) management ports.
100 GbE ports that are changed to 40 GbE ports by dynamically swapping 100 Gb modules with 40 Gb modules. FEC does not support the 40 Gbps speed.
Important
On ports that support FEC configuration, ensure that you configure the same option at both end-points. Otherwise, the link does not come up.
You must enable FEC to achieve proper functionality when using interconnects such as the 25Gb SR, 25 Gb SR-lite, 25 Gb ESR optics or the 25 Gb AOC and 25 Gb DAC.
FEC is not required on 100 Gb or 25 Gb long-range optics because these optics do error checking internally.
This option supports both the 25 Gbps and 100 Gbps speeds. You can configure this option on ports with either the 100GbSR4 or 100GbCR4 modules plugged in, or on 100 GbE channelized ports operating at 25Gbps speed.
Ensure that you enable Auto-Negotiation for ports with the 100GbCR4 modules plugged in; it is mandatory.
This option also supports both the 25 Gbps and 100 Gbps speeds. It is similar to Clause 91 but provides extra latency.
This option supports only the 25 Gbps speed and is used in applications that require reduced latency.
For 25 Gbps speeds, FEC CL108 is enabled for all transceiver types.
FEC is disabled for 100GbE LR4 and ER4 transceivers.
FEC CL91 is enabled for all other transceiver types (for example, 100GbE SR4, CR4, AOC, CWDM4, SWDM4).
FEC is a negotiated port attribute for 25 Gb and 100 Gb connections that support Auto-Negotiation. If you enable Auto-Negotiation on a port for a supported transceiver type, the switch uses the configured FEC value in the negotiation advertisement. Peers can advertise different values, which means the resulting FEC operational state can be different than the one advertised.
The following table lists the 25 Gb end-point advertisements and the resulting FEC operational state:
                                 Peer A  |
                                 Peer B  |
                                 Result  |
                                 CL108  |
                                 CL108  |
                                 CL108  |
                                 CL74  |
                                 CL74  |
                                 CL74  |
                                 No FEC  |
                                 No FEC  |
                                 No FEC  |
                                 No FEC  |
                                 CL108  |
                                 CL108  |
                                 No FEC  |
                                 CL74  |
                                 CL74  |
                                 CL74  |
                                 CL108  |
                                 CL108  |
The following table lists the 100 Gb end-point advertisements and the resulting FEC operational state:
                                 Peer A  |
                                 Peer B  |
                                 Result  |
                                 CL91  |
                                 CL91  |
                                 CL91  |
                                 No FEC  |
                                 No FEC  |
                                 CL91 Note:
                            Even when both peers advertise no FEC, negotiation results in clause 91 FEC per IEEE standard mandatory setting.  |
                                 No FEC  |
                                 CL91  |
                                 CL91  |
You can use the show interfaces gigabitEthernet config command to see the FEC operational state for a port.
For additional details about support, see Default Auto-Negotiation Behavior.
