New hardware switches include a Factory Default Premier Trial License to use all features (excluding MACsec). You can run the extend-time-period command up to three times to extend the trial license. You can configure all features, except MACsec, without restrictions and save the configuration.
You cannot configure new features after the trial period, but the switch continues to run with the existing configured features. If you reboot the switch after the trial period, and a valid software license is not present, licensed features in the configuration are not loaded. You must install a valid license to enable licensed features.
                                 Platform  |
                                 Initial trial period in days  |
                                 VSP 8600 Series  |
                                 30  |
                                 VSP 4450 Series, VSP 4900 Series , VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, VSP 8400 Series, XA1400 Series  |
                                 60  |
The evaluation period is based on the switch System Up Time.
If a Premier license was installed and then revoked, the trial period cannot be extended.
To extend the factory default trial license, see Extend the Factory Default Premier Trial License.
