Display global information about flap-dampening.
Switch(config)# show ip bgp flap-damp-config vrf vrf1
                        BGP Flap Dampening - VRF vrf1
                                           Status - enable
                                       PolicyName - N/A
                                  CutoffThreshold - 1536
                                   ReuseThreshold - 512
                                            Decay - 2
                                      MaxHoldDown - 180
The following table defines parameters for the show ip bgp flap-damp-config command.
 Variable  |
 Value  |
 <prefix/len>  |
 Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32).  |
 vrf WORD<1–16>  |
 Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
 vrfids WORD<0–512>  |
 Specifies a range of VRFs by ID number (the ID ranges from 0–512).  |
