Use the following procedure to edit queues of a queue profile, to configure a queue weight or enable rate limiting on the queue.
After you make the configuration changes, you must apply the queue profile before the changes take effect.
- In the navigation pane, expand the following folders: .
 - Click Queue Profile.
 - Update a queue to configure queue weight or rate limiting.
- Click the Queue tab.
 - Edit the AdminWeight and AdminRateLimitStatus fields by double-clicking on them, and then selecting or typing the new value.
 - Click Apply.
 - Apply the queue profile for the queue configuration to
take effect.
- Click the Queue Profile tab.
 - In the Apply field, double-click and select true.
 - Click Apply.
 - Click the Queue tab again, to verify updates to the OperWeight and the OperRateLimitStatus fields, for the respective queue.
Queue field descriptions
Use the data in the following table to use the Queue tab.
 Field  |
 Description  |
 PId  |
 Displays the queue profile ID.  |
 Id  |
 Displays the queue ID.  |
 AdminWeight  |
                                 Configures the queue weight for weighted round robin (WRR), or the rate-limit in percentage of the link rate for queue shaping enabled on the queue. For rate-limit-enabled queues, 50 indicates 50% bandwidth. The overall rate-limit-enabled queues cannot sum higher than 100 min-weight. If rate-limiting is not enabled, this field configures the weight in the WRR scheduler. These values are not associated with bandwidth percentage. The following list identifies the default minimum weight for each queue:
 OperWeight  |
 Displays the operational weight of the profile, described as a percentage.  |
 AdminRateLimitStatus  |
                                 Enables rate limiting on the queue. By default, rate limiting is enabled (true) for queues 6 and 7 only; it is disabled (false) for queues 0 through 5.  |
 OperRateLimitStatus  |
 Displays the operational status of the queue rate limit.  |
