This procedure does not apply to VSP 8600 Series and XA1400 Series.
Use this procedure to configure the maximum EAP and NEAP MAC clients supported on Auto-sense enabled ports.
If you manually configure values on a specific port(s), then these values will take precedence over the Auto-sense global values.
    enable
    configure terminal
  2. Configure the maximum limit of allowed EAP and NEAP MAC clients supported on the Auto-sense enabled port:
    auto-sense eapol multihost mac-max <1-8192>
Configure a maximum of 10 EAP and NEAP MAC clients supported on Auto-sense enabled ports.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#auto-sense eapol multihost mac-max 10
