Use the following procedure to display the IS-IS statistics and counters.
Switch:1# show isis statistics
                                          ISIS System Stats
LEVEL    CORR   AUTH   AREA   MAX SEQ   SEQ NUM  OWN LSP  BAD ID  PART    LSP DB  AREA   AREA-NAME
         LSPs   FAILS  DROP   EXCEEDED  SKIPS    PURGE    LEN     CHANGES OLOAD
Level-1  0      0      0      0        1        0        0       0       0        HOME    area-9.00.02
Level-1  0      0      0      0        1        0        0       0       0        REMOTE  area-9.00.02
                           Switch:1# show isis int-counters
                                   ISIS Interface Counters
IFIDX    LEVEL   AUTH    ADJ       INIT    REJ   ID LEN  MAX AREA  LAN DIS  AREA  AREA-NAME
                 FAILS   CHANGES   FAILS   ADJ                     CHANGES
Mlt2     Level 1  0       1        0       0      0       0        0        HOME  area-9.00.02
Port1/21 Level 1  0       1        0       0      0       0        0        HOME  area-9.00.02
                           Switch:1# show isis int-l1-cntl-pkts
                        ISIS L1 Control Packet counters
IFIDX      DIRECTION       HELLO        LSP      CSNP         PSNP   AREA   AREA-NAME
Mlt2        Transmitted    13346        231        2           229   HOME   area-9.00.02
Mlt2        Received       13329        230        1           230   HOME   area-9.00.02
Port1/21    Transmitted    13340        227        2           226   HOME   area-9.00.02
Port1/21    Received       13335        226        1           227   HOME   area-9.00.02
The following table defines parameters for the show isis int-counters command.
                                                   Variable  |
                                                   Value  |
                                                   home  |
                                                   Displays the IS-IS interface counters that the system configures in the home area.  |
                                                   remote  |
                                                   Displays the IS-IS interface counters that the system configures in the remote area.  |
The following table defines parameters for the show isis int-l1-cntl-pkts command.
                                                   Variable  |
                                                   Value  |
                                                   home  |
                                                   Displays the IS-IS L1 control packet counters that the system configures in the home area.  |
                                                   remote  |
                                                   Displays the IS-IS L1 control packet counters that the system configures in the remote area.  |
The following table defines parameters for the clear isis stats command.
 Variable  |
 Value  |
 error-counters  |
 Clears IS-IS stats error-counters.  |
 packet-counters  |
 Clears IS-IS stats packet-counters.  |
