The following table and sections list the RFCs that the switch supports.
 Request for comment  |
 Description  |
 draft-grant-tacacs-02.txt  |
 TACACS+ Protocol  |
 RFC 768  |
 UDP Protocol  |
 RFC 783  |
 Trivial File Transfer Protocol (TFTP)  |
 RFC 791  |
 Internet Protocol (IP)  |
 RFC 792  |
 Internet Control Message Protocol (ICMP)  |
 RFC 793  |
 Transmission Control Protocol (TCP)  |
                 RFC 815  |
                 IP Datagram Reassembly Algorithm  |
                 RFC 826  |
                 Address Resolution Protocol (ARP)  |
 RFC 854  |
 Telnet protocol  |
 RFC 894  |
 A standard for the Transmission of IP Datagrams over Ethernet Networks  |
 RFC 896  |
 Congestion control in IP/TCP internetworks  |
 RFC 906  |
 Bootstrap loading using TFTP  |
 RFC 950  |
 Internet Standard Subnetting Procedure  |
 RFC 951  |
 BootP  |
 RFC 959, RFC 1350, and RFC 2428  |
 FTP and TFTP client and server  |
 RFC 1027  |
 Using ARP to implement transparent subnet gateways/Nortel Subnet based VLAN  |
 RFC 1058  |
 RIPv1 Protocol  |
 RFC 1112  |
 Host Extensions for IP Multicasting (IGMPv1)  |
 RFC 1122  |
 Requirements for Internet Hosts  |
 RFC 1195  |
 Use of OSI IS-IS for Routing in TCP/IP and Dual Environments  |
                 RFC 1042  |
                 Encapsulating the Internet Protocol (IP) datagrams and Address Resolution Protocol (ARP) Note:
              Applicable for 802.3 networks only  |
 RFC 1253  |
 OSPF MIB  |
 RFC 1256  |
 ICMP Router Discovery  |
                 RFC 1258 Note:
              Exception: rlogin is only supported on VSP 8600 Series.  |
                 IPv6 Rlogin server  |
 RFC 1305  |
 Network Time Protocol v3 Specification, Implementation and Analysis  |
                                                   RFC 1323  |
                                                   TCP Timestamp (The switch is only compliant if the TCP timestamp is enabled.)  |
 RFC 1340  |
 Assigned Numbers  |
 RFC 1519  |
 Classless Inter-Domain Routing (CIDR): an Address Assignment and Aggregation Strategy  |
 RFC 1541  |
 Dynamic Host Configuration Protocol  |
 RFC 1542  |
 Clarifications and Extensions for the Bootstrap Protocol  |
 RFC 1587  |
 The OSPF NSSA Option  |
 RFC 1591  |
 DNS Client  |
 RFC 1723  |
 RIP v2 — Carrying Additional Information  |
 RFC 1812  |
 Router requirements  |
 RFC 1866  |
 Hypertext Markup Language version 2 (HTMLv2) protocol  |
 RFC 1981  |
 Path MTU discovery  |
 RFC 2068  |
 Hypertext Transfer Protocol  |
 RFC 2080  |
 RIP  |
 RFC 2131  |
 Dynamic Host Control Protocol (DHCP)  |
 RFC 2132  |
 DHCP Options and BOOTP Vendor Extensions  |
 RFC 2138  |
 RADIUS Authentication  |
 RFC 2139  |
 RADIUS Accounting  |
 RFC 2178  |
 OSPF MD5 cryptographic authentication / OSPFv2  |
 RFC 2233  |
 The Interfaces Group MIB using SMIv2  |
 RFC 2236  |
 IGMPv2 Snooping  |
 RFC 2358  |
 Definitions of Managed Objects for the Ethernet-like Interface Types  |
 RFC 2284  |
 PPP Extensible Authentication Protocol  |
 RFC 2328  |
 OSPFv2  |
 RFC 2338  |
 VRRP: Virtual Redundancy Router Protocol  |
 RFC 2362  |
 PIM-SM  |
 RFC 2407  |
 IP Security Domain Interpretation of Internet Security Association and Key Management Protocol (ISAKMP)  |
 RFC 2408  |
 Internet Security Associations and Key Management Protocol (ISAKMP)  |
 RFC 2453  |
 RIPv2 Protocol  |
 RFC 2460  |
 IPv6 base stack  |
 RFC 2462  |
 IPv6 Stateless Address Autoconfiguration  |
 RFC 2463  |
 Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification  |
 RFC 2464  |
 Transmission of IPv6 packets over Ethernet networks  |
 RFC 2474  |
 Definition of the Differentiated Services Field (DS Field) in the IPv4 and IPv6 Headers  |
 RFC 2475  |
 An Architecture for Differentiated Services  |
 RFC 2545  |
 Use of BGP-4 multi-protocol extensions for IPv6 inter-domain routing  |
 RFC 2548  |
 Microsoft vendor specific RADIUS attributes  |
 RFC 2579  |
 Textual Conventions for SMI v2  |
 RFC 2580  |
 Conformance Statements for SMI v2  |
 RFC 2616  |
 Hypertext Transfer Protocol 1.1  |
 RFC 2710  |
 Multicast Listener Discovery (MLD) for IPv6  |
 RFC 2716  |
 PPP EAP Transport Level Security (TLS) Authentication Protocol  |
 RFC 2737  |
 Entity MIB (Version 2)  |
 RFC 2819  |
 RMON  |
 RFC 2865  |
 RADIUS  |
 RFC 2874  |
 DNS Extensions for IPv6  |
 RFC 2918  |
 Route Refresh Capability for BGP-4  |
 RFC 2992  |
 Analysis of an Equal-Cost Multi-Path Algorithm  |
 RFC 3046  |
 DHCP Option 82  |
 RFC 3162  |
 IPv6 RADIUS client  |
 RFC 3246  |
 An Expedited Forwarding PHB (Per-Hop Behavior)  |
 RFC 3315  |
 IPv6 DHCP Relay  |
 RFC 3376  |
 IGMPv3  |
 RFC 3411 and RFC 2418  |
 SNMP over IPv6 networks  |
 RFC 3417  |
 Transport Mappings for SNMP  |
 RFC 3484  |
 Default Address Selection for IPv6  |
 RFC 3513  |
 Internet Protocol Version 6 (IPv6) Addressing Architecture  |
 RFC 3569  |
 An overview of Source-Specific Multicast (SSM)  |
 RFC 3579  |
 RADIUS Support For Extensible Authentication Protocol (EAP)  |
 RFC 3580  |
 IEEE 802.1X Remote Authentication Dial In User Service  |
 RFC 3587  |
 IPv6 Global Unicast Address Format  |
 RFC 3596  |
 RFC 3621  |
 Power Ethernet MIB  |
 RFC 3748  |
 RFC 3810  |
 Multicast Listener Discovery Version 2 (MLDv2) for IPv6  |
 RFC 3825  |
 Dynamic Host Configuration Protocol Option for Coordinate-based Location Configuration Information  |
 RFC 3879  |
 Deprecating Site Local Addresses  |
 RFC 3986  |
 Uniform Resource Identifiers (URI)  |
 RFC 4007  |
 IPv6 Scoped Address Architecture  |
 RFC 4022  |
 MIB for TCP  |
 RFC 4113  |
 MIB for UDP  |
                 RFC 4133  |
                 Entity MIB (version 3)  |
 RFC 4193  |
 Unique Local IPv6 Unicast Address  |
 RFC 4213  |
 IPv6 configured tunnel  |
 RFC 4250–RFC 4256  |
 SSH server and client support  |
 RFC 4291  |
 IPv6 Addressing Architecture  |
 RFC 4293  |
 MIB for IP  |
 RFC 4301  |
 Security Architecture for IPv6  |
 RFC 4302  |
 IP Authentication Header (AH)  |
 RFC 4303  |
 IP Encapsulated Security Payload (ESP)  |
 RFC 4305  |
 Cryptographic algorithm implementation requirements for ESP and AH  |
 RFC 4308  |
 Cryptographic suites for Internet Protocol Security (IPsec)  |
 RFC 4443  |
 ICMP for IPv6  |
 RFC 4541  |
 Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping  |
 RFC 4552  |
 OSPFv3 Authentication and confidentiality for OSPFv3  |
 RFC 4601  |
 Protocol Independent Multicast - Sparse Mode (PIM-SM)  |
                 RFC 4604  |
                 Internet Group Management Protocol Version 3 (IGMPv3) and Multicast Listener Discovery Protocol Version 2 (MLDv2) for Source-Specific Multicast  |
 RFC 4607  |
 RFC 4649  |
 Dynamic Host Configuration Protocol for IPv6 (DHCPv6) Relay Agent Remote-ID Option  |
 RFC 4675  |
 Egress VLAN  |
                 RFC 4750  |
                 OSPFv2 MIB  |
 RFC 4760  |
 Multiprotocol Extensions for BGP-4  |
 RFC 4835  |
 Cryptographic algorithm implementation for ESP and AH  |
 RFC 4861  |
 IPv6 Neighbor discovery  |
 RFC 4862  |
 IPv6 stateless address autoconfiguration  |
 RFC 4893  |
 BGP Support for Four-octet AS Number Space  |
 RFC 5095  |
 Deprecation of Type 0 Routing headers in IPv6  |
 RFC 5176  |
 Dynamic Authorization Extensions to Remote Authentication Dial In User Service (RADIUS)  |
 RFC 5187  |
 OSPFv3 Graceful Restart (helper-mode only)  |
 RFC 5242  |
 The Syslog Protocol  |
 RFC 5321  |
 Simple Mail Transfer Protocol  |
 RFC 5340  |
 OSPF for IPv6  |
                 RFC 5746  |
                 Secure SSL Renegotiation  |
 RFC 5798  |
 Virtual Router Redundancy Protocol (VRRP) Version 3 for IPv4 and IPv6  |
 RFC 5905  |
 Network Time Protocol Version 4: Protocol and Algorithms Specification  |
 RFC 5997  |
 Use of Status-Server Packets in the Remote Authentication Dial In User Service (RADIUS) Protocol  |
 RFC 6105  |
 IPv6 Router Advertisement Guard  |
 RFC 6329  |
 IS-IS Extensions supporting Shortest Path Bridging  |
 RFC 7047  |
 The Open vSwitch Database Management Protocol  |
 RFC 7348  |
 Virtual Extensible LAN (VXLAN)  |
 RFC 7610  |
 DHCPv6 Shield  |
