Change the PIM interface status to active to allow PIM control traffic on the interface.
The PIM interface is disabled.
The command you use depends on the required administrative state of the interface (enable or disable).
Variable definitions
Use the data in the following table to use the ip pim command.
 Variable  |
 Value  |
 active  |
 Configures the selected interface. You can change the state of a PIM interface after you create the interface but only if you first disable PIM on the interface. An active interface permits PIM control transmitted and received traffic. A passive interface prevents PIM control traffic from transmitting or receiving, thereby reducing the load on a system. This feature is useful if a high number of PIM interfaces exist and connect to end users, not to other switches. The default is active. To configure this option to the default value, use the default operator with the command.  |
 passive  |
