This procedure only applies to VSP 4450 Series.
View port policer statistics to manage network performance.
 - Select Port.
 - Select the Policer tab.
Policer Field Descriptions
Use the data in the following table to use the Policer tab.
 Name  |
 Description  |
 TotalPkts  |
 Shows the total number of packets received on the port.  |
 TotalBytes  |
 Shows the total number of bytes received on the port.  |
 YellowBytes  |
 Shows the total number of bytes received on the port that were above the committed rate but below the peak rate.  |
 RedBytes  |
 Shows the total number of bytes received on the port that were above the peak rate.  |
