View all of the ACE ARP entries associated with an ACL.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click Arp.
 - To modify a parameter, double-click the parameter, select the option, and then click Apply.
ARP field descriptions
Use the data in the following table to use the ARP tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Type  |
 Specifies the ACE ARP operation. The only option is operation.  |
 Oper  |
 Specifies the operator for the ACE ARP operation. The only option is eq (equal).  |
 Value  |
 Specifies the ARP packet type. Valid options are arpRequest and arpResponse.  |
