This procedure only applies to the VSP 7400 Series.
Perform this procedure to apply the Multi-area SPB layer 2 multicast redistribution that you configure in the remote area.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select MultiArea
  3. Select the L2 MC Apply Remote tab.
  4. In the McastApply field, select apply.
L2 MC Apply Remote Field Descriptions
Use data in the following table to use the L2 MC Apply Remote tab.
Name Description
McastApply
Applies or disables the Multi-area SPB layer 2 multicast redistribution in the remote area.
  • noAction
  • apply
