Delete an EAP-enabled RADIUS server if you want to remove the server.
RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# no radius server host fe79:0:0:0:21d:4fdf:fe5e:73fd used-by eapol
The following table defines parameters for the radius server host WORD<0–46> usedby eapol command.
 Variable  |
 Value  |
 host WORD<0–46>  |
 Specifies the IP address of the selected server. This address tells the device where to find the RADIUS server, from which it obtains EAP authentication and user role information. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration.  |
 key WORD<0-20>  |
 Specifies the shared secret key that you use for RADIUS authentication. The shared secret is held in common by the RADIUS server and all EAP-enabled devices in your network. It authenticates each device with the RADIUS server as an EAP access point. When you configure your RADIUS server, you must configure the same shared secret value as you specify here.  |
