Run a Traceroute Test
Use traceroute to determine the route packets take through a network to a destination.
Ping and traceroute can fail for VRF routes if you use large packet sizes for the operation. Do not use packet sizes larger than the following:
Ping for VRF: 1480 bytes
Traceroute for VRF: 1444 bytes
Exception: large packet sizes are supported when running ping and traceroute on the Segmented Management Instance.
Run a traceroute test with a probe packet size of 200 and a max time to live of 60:
Switch:1>enable Switch:1#traceroute 192.0.2.33 200 —m 60
Run a traceroute test for an IPv6 address:
Switch:1#traceroute 2001:db8::1
Run a traceroute test using the management routing table:
Switch:1#traceroute 192.0.2.12 mgmt
Run a traceroute test using a management CLIP:
Switch:1#traceroute 192.0.2.12 mgmt clip
Run a traceroute test using a management VLAN:
Switch:1#traceroute 192.0.2.12 mgmt vlan
The following table defines parameters for the traceroute command.
Variable |
Value |
-m <1-255> |
Specifies the maximum time-to-live (TTL). |
-p <1-65535> |
Specifies the base UDP port number. The default is 33434. Note:
If the traceroute action is directed to an IPv6 host address, Linux increments the UDP port on a per-TTL basis. For an IPv4 host address, Linux increments the UDP port on a per-probe basis. Because the traceroute command sends a default of three probes, three incrementing ports will be sent for an IPv4 host address. If you use the -p parameter with a value greater than 65533, the traceroute command fails for an IPv4 host address because the maximum port number, 65535, is exceeded. If you send a traceroute probe into the device through the Segmented Management Instance or any routing interface, you must use the default UDP port range of 33434 to 33534. Using other ports will fail. |
-q <1-255> |
Specifies the number of probes per TTL. |
-v |
Specifies verbose mode (detailed output). This parameter does not apply if you use the mgmt [clip | oob | vlan] parameter. |
-w <1-255> |
Specifies the wait time for each probe. |
<1-1176> |
Specifies the size of the probe packet. |
grt Note:
Exception: not supported on VSP 8600 Series |
Specifies the traceroute command is executed in grt context. |
mgmt [<clip | oob | vlan>] Note:
Exception: oob not supported on VSP 4450 Series , XA1400 Series, or VSP 8600 Series Note:
Exception: vlan not supported on VSP 8600 Series |
Specifies the Segmented Management Instance as the source for the outgoing packet. The packet goes out this specific interface only. If you do not specify the management interface type, the traceroute command uses the management routing table to determine the best management interface and selects the source IP based on the egress management interface. |
source <WORD 1-256> |
Specifies the source IP address. This parameter does not apply if you use the mgmt [clip | oob | vlan] parameter. |
WORD<0-256> |
Specifies the destination IPv4 or IPv6 address, or hostname. |
vrf <WORD 1-16> |
Specifies the VRF instance by VRF name. This parameter does not apply if you use the mgmt [clip | oob | vlan] parameter. |
