Configure the packet sampling rate at port level to determine how many packets the system counts before it takes a sample. Configuring the sampling rate enables sFlow on the port.
You must globally enable sFlow.
If you configure a conservative sampling rate to prevent overloading the sFlow agent, the result will reflect high values that do not reflect typical traffic levels.
Configure sampling rates for ports 2/1, 2/2, 2/3, and 2/4.
Switch:1(config-if)#interface gigabitethernet 2/1,2/2
Switch:1(config-if)#sflow collector 1
Switch:1(config-if)#sflow sampling-rate 10000
Switch:1(config-if)#interface gigabitethernet 2/3
Switch:1(config-if)#sflow collector 2
Switch:1(config-if)#sflow sampling-rate 8192
Switch:1(config-if)#interface gigabitethernet 2/4
Switch:1(config-if)#sflow sampling-rate 12001
Switch:1(config-if)#show sflow interface enabled
                         sFlow Port Configuration Info
Port   Packet-Sample-Rate  Max-Header-Size Counter-interval  Collector-list
                                           (in secs)
2/1    10000               128             0                 1
2/2    10000               128             0                 1
2/3    8192                128             0                 2
2/4    12001               128             0                 2
All 4 out of 4 Total Num of sflow port entries displayed
Use the data in the following table to use the sflow sampling-rate and show sflow interface commands.
                             Variable  |
                             Value  |
                             <1024–1000000>  |
                             Configures the packet sampling rate on a port. The default value is 0 (disabled). To configure the default value, enter default sflow sampling-rate.  |
                             {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
