25 GbE ports typically support 25 Gbps, 10 Gbps, and 1 Gbps operational speeds. Auto-Negotiation support varies depending on the pluggable type and speed.
The following table provides a summary of Auto-Negotiation support for 25 Gbps ports.
Table 1. 25 Gbps Port Auto-Negotiation
Transceiver Type
25 Gbps DAC
Supported
Note:
Exception: VIM5-2Y and VIM5-4Y do not support Auto-Negotiation at 25 Gbps.
25 Gbps SR, LR, AOC
Not Supported
10 Gbps
Not Supported
1 Gbps
Note:
Not Supported for VSP 7400-48Y.
Forward Error Correction (FEC) is a negotiated port attribute for 25 GbE connections that support Auto-Negotiation. For more information, see Forward Error Correction.
