View Ping Results
View ping results to view performance-related data.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
 - Click Ping/Trace Route.
 - Click the Ping Control tab.
 - Select a ping test entry.
 - Click Ping Result.
Ping Result Field Descriptions
Use the data in the following table to use the Ping Result tab.
 Name  |
 Description  |
 OwnerIndex  |
 Specifies the ping test owner.  |
 TestName  |
 Specifies the test name.  |
 OperStatus  |
 Indicates the operational status of the test. The default is disabled.  |
 IpTargetAddressType  |
 Specifies the IP address type of the target. The default is unknown.  |
 IpTargetAddress  |
 Specifies the IP address of the target.  |
 MinRtt  |
 Specifies the minimum ping round-trip-time (RTT) received. A value of 0 means that no RTT is received.  |
 MaxRtt  |
 Specifies the maximum ping RTT received. A value of 0 means that no RTT is received.  |
 AverageRtt  |
 Specifies the current average ping RTT.  |
 ProbeResponses  |
 Specifies the number of responses to probes.  |
 SentProbes  |
 Specifies the number of sent probes.  |
 RttSumOfSquares  |
 Specifies the sum of squares of RTT for all probes received.  |
 LastGoodProbe  |
 Specifies the date and time when the last response is received for a probe.  |
