View RMON control tables to see the data source for both network layer and application layer host statistics.
Switch:1# show rmon ctl-table
                               Rmon Control Table
                            Protocol Directory Table
IDX  PROTOCOL  ADDRMAPCFG  HOSTCFG    MATRIXCFG     OWNER
1    IP        SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
2    TCP       SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
3    UDP       SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
4    FTP       SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
5    SSH       SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
6    TELNET    SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
7    HTTP      SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
8    RLOGIN    SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
9    TFTP      SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
10   SNMP      SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
11   HTTPS     SUPPORTED   SUPPORTED  NOT SUPPORTED Switch-1
                          Protocol Distribution Control Table
IDX  DATASOURCE       DROPFRAMES  CREATETIME         OWNER
1    0.0.0.0          0           09/22/15 19:29:13  Switch-1
                           Address Map Control Table
IDX  DATASOURCE       DROPFRAMES  OWNER
1    0.0.0.0          0           Switch-1
                               Host Control Table
IDX  DATASOURCE       NHDROPFRAMES  AHDROPFRAMES  OWNER
1    0.0.0.0          0            0            Switch-1
Protocol support can vary across platforms.
