View the IPv4 address bindings that IPSG allows.
 - Select Source Guard.
 - Select the IP Source Guard-addresses tab.
IP Source Guard-addresses field descriptions
Use the data in the following table to use the IP Source Guard-addresses tab.
                         Field  |
                         Description  |
                         Port  |
                         Indicates the port on which IPSG is configured.  |
                         Type  |
                         Indicates the address type.  |
                         Address  |
                         Indicates the IPv4 address that is allowed by IPSG on the port.  |
                         Source  |
                         Indicates the source of the IPv4 address, which is DHCP Snooping.  |
