The system validates the number of license entitlements against the IOC modules present and assigns the licenses sequentially to the I/O slots, starting from slot 1 to slot 8.
If you install a module in a slot that has a license assigned and later, when the module is moved to another slot that does not have a license assigned, you can reassign the license to the new slot.
License Grant field descriptions
Use the data in the following table to use the License Grant tab.
 Name  |
 Description  |
 Slot  |
 Specifies the IO slot number. Valid slots are 1 to 8.  |
 SlotGrant  |
 Specifies the license status on the IO slot.
