This procedure does not apply to
VSP 8600
					Series and
XA1400
					Series.
            Perform this procedure to configure an Auto-sense Data I-SID on a port.
                In the Device Physical
                        View tab, select a port.
                In the navigation pane, expand
                Select General.
                Select the Interface
                    tab.
                For AutoSenseDataIsid, type the data I-SID value. The range is 0 to
                    15999999.
                Select Apply.
