Controls the format of the syslog output and logging. By default, the switch uses the RFC 5424 format. If the RFC-based format is disabled, an older format is used.
    enable
    configure terminal
  2. Configure the output format:
    boot config flags syslog-rfc5424-format
  3. Save the changed configuration.
