Use the Addresses tab to view IP addresses (and their associated router interfaces) from one central location.
 - Click IP.
 - Click the Addresses tab.
Addresses field descriptions
Use the data in the following table to use the Addresses tab.
 Name  |
 Description  |
 Interface  |
 Specifies the router interface.
 Ip Address  |
 Specifies the IP address of the router interface.  |
 Net Mask  |
 Specifies the subnet mask of the router interface.  |
 BcastAddrFormat  |
 Specifies the IP broadcast address format used on this interface; that is, whether 0 (zero) or one is used for the broadcast address. The switch uses 1.  |
 ReasmMaxSize  |
 Specifies the size of the largest IP packet that this interface can reassemble from incoming fragmented IP packets.  |
 VlanId  |
 Identifies the VLAN associated with this entry. This value corresponds to the lower 12 bits in the IEEE 802.1Q VLAN tag.  |
 BrouterPort  |
 Indicates whether this is a brouter port (as opposed to a routable VLAN).  |
 MacOffset  |
 Specifies a number by which to offset the MAC address of the VLAN from the chassis MAC address. This ensures that each IP address has a different MAC address.  |
