This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote Intermediate-System-Intermediate-System (IS-IS) interface counters.
 - Select Stats Remote.
 - Select the Interface Counters tab.
Interface Counters Field Descriptions
Use the data in the following table to use the Interface Counters tab.
 Name  |
 Description  |
 Index  |
 Shows a unique value identifying the IS-IS interface.  |
 Level  |
 Shows the type of circuit that discovered the interface counters. The point to point Hello PDU includes both Layer 1 and Layer 2, and IS from a single adjacency on point to point links, therefore combining counts on point to point links into one group.  |
 AdjChanges  |
 Shows the number of times an adjacency state change has occurred on this circuit.  |
 InitFails  |
 Shows the number of times initialization of this circuit has failed. This counts events such as PPP NCP failures. Failures to form an adjacency are counted by isisCircRejAdjs.  |
 RejAdjs  |
 Shows the number of times an adjacency has been rejected on this circuit.  |
 IDFieldLenMismatches  |
 Shows the number of times an IS-IS control PDU with an ID field length different to that for this system has been received.  |
 MaxAreaAddrMismatches  |
 Shows the number of times an IS-IS control PDU with a max area address field different to that for this system has been received.  |
 AuthFails  |
 Shows the number of times an IS-IS control PDU with the correct auth type has failed to pass authentication validation.  |
 LANDesISChanges  |
 Shows the number of times the Designated IS has changed on this circuit at this level. If the circuit is point to point, this count is zero.  |
