You can use a circuitless IPv4 (CLIPv4) interface to provide uninterrupted connectivity to your system.
 - Select IP.
 - Select the Circuitless IP tab.
 - Select Insert.
 - In the Interface field, assign a CLIP interface number.
 - Enter the IP address.
 - Enter the network mask.
 - Select Insert.
 - To delete a CLIP interface, select the interface and select Delete.
Use the data in the following table to use the Circuitless IP tab.
 Name  |
 Description  |
 Interface  |
 Specifies the number assigned to the interface.  |
 Ip Address  |
 Specifies the IP address of the CLIP.  |
 Net Mask  |
 Specifies the network mask.  |
| Name | Specifies the name assigned to the IPv4 CLIP address. |
