Configuring ARP ACEs
Use ACE Address Resolution Protocol (ARP) entries to ensure the filter looks for ARP requests or responses.
You cannot configure ARP attributes for IPv6 filters.
The ACL exists.
The ACE exists.
Use the data in the following table to use the filter acl ace arp command.
                             Variable  |
                             Value  |
                             <acl-id>  |
                             Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
                             <ace-id>  |
                             Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.  |
                             operation eq <arprequest|arpresponse>  |
                             Specifies the type of ARP operation to filter: arpRequest or arpResponse.  |
