Originator ID cannot be deleted if MSDP is enabled.
 - Click MSDP.
 - Click the Globals tab.
 - In the RPAddress box, type the IP address to use as the originator ID.
 - Click Apply.
Global field descriptions
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 Enabled  |
 Enables MSDP. If you clear this check box, you disable MSDP. The default setting is clear (disabled).  |
 CacheLifetime  |
 Configures the lifetime given to SA cache entries when created or refreshed.  |
 NumSACacheEntries  |
 Displays the total number of entries in the SA cache.  |
 RPAddress  |
 Specifies the IP address to use as the originator ID. If the address is not a system local address, the system rejects the configuration.  |
 RouteMapName  |
 Specifies the name of the optional route policy to create or modify. You do not need to create a route policy to use the redistribution filter. Note:
To delete the route map name, clear the field and click Apply.  |
 RedistributeFilterEnabled  |
 Filters the (S,G,RP) entries provided by PIM to MSDP. The default is clear (disabled).  |
 RedistruteFilterApply  |
 Applies the changes made to the redistribute filter.  |
 StatsClear  |
 Clears MSDP statistics.  |
