Create an access policy to determine the access level for the users who connect to the switch with different services like File Transfer Protocol (FTP), Trivial FTP (TFTP), Telnet, and rlogin.
Rlogin is only supported on VSP 8600 Series.
You only need to create access policies for SNMP groups if you have the access policy feature enabled.
 - Select Access Policies.
 - Select the Access Policies-SNMP Groups tab.
 - Select Insert.
 - Enter an ID .
 - In the Name box, type a name.
 - From the Model options, select a security model.
 - Select Insert.
Access Policies — SNMP Groups field descriptions
The following table defines parameters for the Access Polices-SNMP Groups tab.
 Name  |
 Description  |
 Id  |
 Specifies the ID of the group policy.  |
 Name  |
 Specifies the name assigned to the group policy. The range is 1–32 characters.  |
 Model  |
 Specifies the security model {SNMPv1|SNMPv2c|USM}.  |
