Configuring OVSDB globally
Use the following procedure to configure the OVSDB certificates, private key, and replication global settings.
 - Click OVSDB.
 - Click the Globals tab.
 - Select Enable.
 - In the CertificateFilename field, type the filepath/filename.
 - In the CertFileInstallAction field, select install.
 - Click Apply.
 - In the PrivateKeyFilename field, type the filepath/filename.
 - In the PrivateKeyInstallAction field, select install.
 - Click Apply.
 - Select ReplicationEnable.
 - In the ReplicationPeerIpAddr field, type the IP address.
 - In the ReplicationLocalIpAddr field, type the IP address.
 - Click Apply.
 - Verify the ReplicationState.
Globals field descriptions
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 Enable  |
 Enables or disables the feature. Default is disabled (cleared).  |
 CertificateFilename  |
 Specifies the filename of the certificate.  |
 CertFileInstallAction  |
 Specifies to install or uninstall the certificate. You must have a certificate file on the switch.  |
 PrivateKeyFilename  |
 Specifies the filename of the private key.  |
 PrivateKeyInstallAction  |
 Specifies to install or uninstall the private key. You must have a private key file on the switch.  |
 ReplicationEnable  |
 Enables or disables replication support. Default is disabled (cleared).  |
 ReplicationPeerIpAddr  |
 Specifies the replication server peer IP address in A.B.C.D format.  |
 ReplicationLocalIpAddr  |
 Specifies the replication local IP address in A.B.C.D format.  |
 ReplicationState  |
 Displays the current replication status.  |
