Display the current device configuration.
Use the clear-stats command to clear EAP or NEAP statistics.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the current device configuration by using the following command:
    show eapol system
Product Notice: auto-isid-offset functionality is not available on VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Switch:1>show eapol system
                                  Eapol System
                     eap : disabled
           Eapol Version : 3
         non-eap-pwd-fmt : mac-addr
     non-eap-pwd-fmt key : ******
 non-eap-pwd-fmt padding : disabled
 auto-isid-offset status : disabled
 auto-isid-offset value  : 1000
