Important
Product Notice: VSP 8600 Series supports Policy Based Routing (Redirect Next Hop) Per VRF as a demo feature. Do not use this feature in production environments.
The access control entry (ACE) exists.
If you use the mirror action, ensure that you specify the mirroring destination: MLTs or ports.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# filter acl ace action 901 1 permit monitor-dst-mlt 5
The following table defines parameters for the filter acl ace action command.
 Variable  |
 Value  |
 1-2048  |
 Specifies the ACL ID from 1–2048  |
 1-2000  |
 Specifies the ACE ID from 1–2000.  |
 monitor-dst-mlt <1–512>  |
 Configures mirroring to a destination MLT group.  |
 monitor-dst-ports {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Configures mirroring to a destination port or ports.  |
 {permit|deny}  |
 Configures the action mode for security ACEs. The default value is permit.  |
