You must enable SSH globally before you can generate DSA user keys.
The following table defines parameters for the ssh dsa-user-key command.
| Variable | Value |
| WORD <1–15> |
                             Specifies the user access level. You must enable SSH globally before you can generate SSH DSA user keys. If enhanced secure mode is disabled, the valid user access levels for the switch are:
 If you enable enhanced secure mode, the switch uses role-based authentication. You associate each username with a specific role and the appropriate authorization rights to commands based on that role. If enhanced secure mode is enabled, the valid user access levels for the switch are:
                             size <1024-1024>  |
                             Specifies the size of the DSA user key.  |
