Enable NTP globally. Default values are in effect for most parameters. You can customize NTP by modifying parameters.
Specify the time interval between NTP updates, and then enable NTP globally.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ntp interval 10 Switch:1(config)#ntp
Switch:1(config)#show ntp
                                   NTP Master
Version   Enabled    Stratum
4         False      10
                                   NTP Client
Version  Enabled   Interval  Last Update Time                Synchronized To
4        True      10        Thu Jul 18 08:32:59 2019 EDT    192.0.2.0 (Stratum:2)
The following table defines parameters for the ntp command.
                                 Variable  |
                                 Value  |
                                 authentication-key <1–65534> WORD<0–20>  |
                                 Creates an authentication key for MD5 or SHA1 authentication. The default configuration is to delete the authentication key. NTP server MD5 or SHA1 authentication does not support passwords (keys) that start with a special character or contain a space between characters. WORD<0–20> specifies the secret key.  |
                                 type <md5 | sha1>  |
                                 Specifies the type of authentication as MD5 or SHA1. The default is MD5 authentication.  |
                                 interval<1–2185> OR <4-17> Note:
                            Exception: interval range 1-2185 is supported on VSP 8600 Series only.  |
                                 VSP 8600 Series: Specifies the time interval between successive NTP updates in minutes. The default for NTPv3 is 15 minutes. The default for NTPv4 is 6 minutes. VOSS switches: Specifies the time interval between successive NTP updates as a power of 2 in seconds. The default for NTPv4 is 2 to the power of 8 seconds. Note:
                                Exception: NTPv3 is supported on VSP 8600 Series only.  |
