Perform this procedure to view the I-SID bridge forwarding database.
The show i-sid mac-address-entry command displays the C-MACs learned on T-UNI I-SIDs. It also displays the C-MACs learned on T-UNI I-SIDs for a specific I-SID, MAC address, port or port list or remote MAC address.
View C-MACs learned on all T-UNI I-SIDs.
Switch:1#show i-sid mac-address-entry
                                         I-SID Fdb Table
I-SID   STATUS     MAC-ADDRESS         INTERFACE  TYPE      DEST-MAC          BVLAN  DEST-SYSNAME        AREA-ROLE        AREA-NAME
100     learned    cc:f9:54:ae:28:81   Port-1/16  LOCAL     00:00:00:00:00:00 	 0                   HOME             area-20.0020
4       learned    cc:f9:54:ae:2c:18   mlt-6      LOCAL     00:00:00:00:00:00 	 0                   HOME             area-20.0020
252     learned    cc:f9:54:ae:38:64   Port-1/15  NON-LOCAL 00:13:0a:0c:d3:e0  128   DIST-1B             REMOTE           area-30.0030
All 3 out of 3 Total Num of i-sid FDB Entries displayed
View C-MACs learned on a specific T-UNI I-SID.
Switch:1#show i-sid mac-address-entry 100
                                         I-SID Fdb Table
All 1 out of 1 Total Num of i-sid FDB Entries displayed
Switch:1#show i-sid mac-address-entry 252
                                         I-SID Fdb Table
View C-MACs learned on a T-UNI I-SID for a specific MAC address.
Switch:1#show i-sid mac-address-entry mac cc:f9:54:ae:38:64
                                         I-SID Fdb Table
View C-MACs learned on aT-UNI I-SID for a specific port.
Switch:1#show i-sid mac-address-entry port 1/15
                                         I-SID Fdb Table
View C-MACs learned on a T-UNI I-SID as a remote MAC address.
Switch:1#show i-sid mac-address-entry remote
                                         I-SID Fdb Table
            View C-MACs learned on a T-UNI I-SID as a home MAC address.
Switch:1#show i-sid mac-address-entry home
                                                              I-SID Fdb Table
            View C-MACs learned on a T-UNI I-SID as a non-local MAC address.
Switch:1#show i-sid mac-address-entry non-local
                                                              I-SID Fdb Table
The following table defines parameters for the show i-sid mac-address-entry command.
 Variable  |
 Value  |
 <1-16777215>  |
 Displays the MAC address learned on the service interface identifier (I-SID).  |
                             home  |
                             Filters the command output to show only MAC addresses learned in the home area.  |
 mac <0x00:0x00:0x00:0x00:0x00:0x00>  |
 Displays the I-SID FDB details for the specified MAC address.  |
                             non-local  |
                             Filters the command output to show only MAC addresses learned from other nodes; not local nodes.  |
 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Displays the MAC address learned on the specified port or port list.  |
 remote  |
                             Filters the command output to show only MAC addresses learned in the remote area.  |
