Edit system identification information, configuration file information, and perform system actions.
 - Click Chassis.
 - Click the System tab.
 - Enter or edit the information as required.
 - Click Apply.
System Field Descriptions
Use the data in the following table to use the System tab.
                                 Name  |
                                 Description  |
                                 sysDescr  |
                                 Shows the system assigned name and the software version.  |
                                 sysUpTime  |
                                 Shows the elapsed time since the system last started.  |
                                 sysContact  |
                                 Configures the contact information.  |
                                 sysName  |
                                 Configures the name of this device.  |
                                 sysLocation  |
                                 Configures the physical location of this device.  |
                                 VirtualIpAddr  |
                                 Configures the virtual IP address that the primary CPU advertises and stores in the switch configuration file.  |
                                 VirtualNetMask  |
                                 Configures the net mask of the virtual management IP address.  |
                                 VirtualIpv6Addr  |
                                 Specifies the virtual IPv6 address.  |
                                 VirtualIpv6PrefixLength  |
                                 Specifies the length of the virtual IPv6 address prefix (in bits).  |
                                 DnsDomainName  |
                                 Configures the default domain for querying the DNS server.  |
                                 LastChange  |
                                 Displays the time since the last configuration change.  |
                                 LastVlanChange  |
                                 Displays the time since the last VLAN change.  |
                                 LastStatisticsReset  |
                                 Displays the time since the statistics counters were last reset.  |
                                 LastRunTimeConfigSave  |
                                 Displays the last run-time configuration saved.  |
                                 DefaultRuntimeConfigFileName  |
                                 Displays the default Run-time configuration file directory name.  |
                                 ConfigFileName  |
                                 Specifies the name of a new configuration file.  |
                                 ActionGroup1  |
                                 Performs one of the following actions:
                                 LicenseFileName Note:
                            Exception: only supported on the VSP 8600 Series and the XA1400 Series.  |
                                 Specifies the name of the license file in the /intflash directory.  |
                                 ActionGroup2  |
                                 Specifies the following action: resetlstStatCounters—Resets the IST statistic counters  |
                                 ActionGroup3  |
                                 Can be the following action:
                                 ActionGroup4  |
                                 Result  |
                                 Displays a message after you select Apply.  |
                                 LocatorLED Note:
                            Exception: only supported on VSP 4900 Series.  |
                                 Configures the system Locator LED on or off. The default is off.  |
