Use the following procedure to view a summary of SPBM and IS-IS protocol information.
 - Select IS-IS.
 - Select the Protocol Summary tab.
Protocol Summary field descriptions
Use the data in the following table to use the Protocol Summary tab.
 Name  |
 Description  |
                                 Globals ISIS  |
 AdminState  |
 Indicates the global status of IS-IS on the switch.  |
 SystemId  |
 Indicates the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx>  |
 HostName  |
 Indicates IS-IS system name. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763. By default, IS-IS system name uses global system name as it is synchronized with the IS-IS system name until the IS-IS sytem name is manually configured.  |
                                 Globals SPBM  |
 GlobalEnable  |
 Indicates whether SPBM is enabled or disabled at the global level.  |
 NodeNickName  |
 Indicates the nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>.  |
 PrimaryVlan  |
 Indicates the primary VLAN ID for this SPBM instance.  |
 SmltSplitBEB  |
 Indicates whether the switch is the primary or secondary IST peer.  |
                                 ISIS Interfaces  |
 Circuit Index  |
 Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This is for SNMP Indexing purposes only and need not have any relation to any protocol value.  |
 IfIndex  |
 Indicates the interface to which this circuit corresponds.  |
 AdminState  |
 Indicates the administrative state of the circuit: on or off.  |
 OperState  |
 Indicates the operational state of the circuit: up or down.  |
                                 ISIS Adjacency View  |
 Circuit Index  |
 Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value.  |
 AdjIndex  |
 Displays a unique value identifying the IS adjacency from all other such adjacencies on this circuit. This value is automatically assigned by the system when the adjacency is created  |
 AdjIfIndex  |
 AdjState  |
 Indicates the state of the adjacency:
 AdjNeighSysID  |
 Indicates the system ID of the neighboring Intermediate System.  |
 AdjHostName  |
 Indicates the host name listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if the host name is not configured.  |
