Exception: only supported on VSP 8600 Series.
Activates or disables automatic save of the configuration file to the standby CPU. The default value is enabled. If you operate a dual CPU system, enable this flag for ease of operation.
    enable
    configure terminal
  2. Enable automatic saving of the configuration file to the standby CPU:
    boot config flags savetostandby
  3. Save the changed configuration.
