This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure layer 2 I-SID list.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select MultiArea.
  3. Select the L2 ISID List tab.
  4. Select Insert.
  5. Configure the layer 2 I-SID list parameters.
  6. Select Insert.
L2 I-SID List Field Descriptions
Use data in the following table to use the L2 I-SID List tab.
Name Description
Name
Specifies the name of the layer 2 I-SID list.
RangeStart
Specifies the I-SID value as the starting range for the layer 2 I-SID list.
RangeEnd
Specifies the I-SID value as the ending range for the layer 2 I-SID list.
