Configure community lists to specify permitted routes by BGP extended community attributes, including route targets and sites of origin (SOO). This list acts as a filter that matches route targets and SOO.
Configure BGP on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip bgp. The VRF must have an RP Trigger of BGP.
Route refresh is not currently supported on non-default VRFs.
Create an extended community list based on the route target attribute:
Switch(config)# ip extcommunity-list 1 memberid 234 rt 192.0.2.1 5 soo 32 45
The following table defines parameters for the ip extcommunity-list command.
 Variable  |
 Value  |
 <1-1024>  |
 Specifies an integer value from 1–1024 that represents the community list ID you want to create or modify.  |
 memberId <0-65535>  |
 Specifies an integer value from 0–65535 that represents the member ID in the community list.  |
 rt <0-65536> <0-2147483647> rt <A.B.C.D> <0-65535>  |
 Specifies the route target in the format {AS number:assigned number} (that is, {0–65535}:{0–2147483647}) or {ipaddress:assigned number} (that is, {a.b.c.d}:{0–65535}).  |
 soo <0-65535> <0-2147483647> soo <A.B.C.D> <0-65535>  |
 Specifies the site of origin in the format {AS number:assigned number} (that is, {0–65535}:{0–2147483647}) or {ipaddress:assigned number} (that is, {a.b.c.d}:{0–65535}).  |
