Use the following procedure to configure a Transparent Port UNI or Switched UNI by mapping an I-SID to a port or MLT and VLAN together.
If you are configuring a T-UNI to terminate on a port or MLT on a switch in a vIST switch cluster, you must also configure the T-UNI I-SID on the other switch of the vIST switch cluster. You must configure the T-UNI I-SID on both switches of a vIST pair. It is not necessary to assign an actual port or MLT to the T-UNI on the second switch.
You must enable Flex UNI to create a Switched UNI service.
You must first create a type of service instance identifier (I-SID) to create the different types of services available. After you create an I-SID you can add members (ports or MLTs) to the I-SID to create end-points for the service.
 - Select ISID.
 - Select the Service tab.
                To create a Transparent Port UNI service:
- Select Insert.
 - Select elan Transparent in the Type field.
 - Enter the I-SID in the Id field.
 - To create a Switched UNI service:
- Select Insert.
 - Select elan in the Type field.
 - Select Insert.
Service Field Descriptions
Use the data in the following table to use the Service tab.
                                 Name  |
                                 Description  |
                                 ID  |
                                 Specifies a unique value to identify the service associated with this entry.  |
                                 Type  |
                                 Specifies the type of service associated with this entry.  |
                                 MacLimitEnable  |
                                 Indicates whether the MAC limit is enabled (true) or disabled (false).  |
                                 MaxMacLimit  |
                                 Indicates the maximum learned value of the MAC address for each service I-SID.  |
                                 Action  |
                                 Specifies I-SID related actions.  |
                                 OriginBitMap  |
                                 Specifies the origin of the I-SID.  |
                                 VnId  |
                                 Identifies the VXLAN service associated with this I-SID.  |
                                 Name Note:
                            This field does not apply to all hardware platforms.  |
                                 Specifies the name of the I-SID.  |
