Use the following procedure to configure Wake-On-LAN functionality.
This procedure does not apply to VSP 8600 Series or XA1400 Series.
The following table defines parameters for the eapol traffic-control command.
                             Variable  |
                             Value  |
                             in  |
                             Specifies incoming traffic is blocked when there is no authenticated device.  |
                             in-out  |
                             Specifies incoming and outgoing traffic is blocked when there is no authenticated device. The default value is in-out.  |
