Use the following procedure to display the configured IKEv2 profiles.
Switch:1#show ike v2-profile test
                                  IKE2 Profile
                                 Hash               Encrypt                  Encrypt       Exchange
Name                             Algo               Algo                     Key Length    Mode
test                             sha256                aesCbc                   256        main
                                  IKE2 Profile
                                 DH                           Integrity                  Lifetime
Name                             Group                        Algorithm                  seconds
test                             modp2048                     sha256                     180
The following table defines parameters for the show ike v-2profile command.
 Variable  |
 Value  |
 WORD<1–32>  |
 Specifies the name of the policy.  |
