Configure community lists to specify permitted routes by using their BGP community. This list acts as a filter that matches communities or AS numbers.
You configure BGP on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip bgp. The VRF must have an RP Trigger of BGP.
Route refresh is not currently supported on non-default VRFs.
Create a community list:
Switch(config)# ip community-list 1 memberid 4551 permit community-string internet
The following table defines parameters for the ip community-list command.
 Variable  |
 Value  |
 <0-65535>  |
 Specifies an integer value from 0–65535 that represents the member ID in the community list.  |
 <1-1024>  |
 Specifies an integer value from 1–1024 that represents the community list ID.  |
 <permit|deny>  |
 Configures the access mode, which permits or denies access for matching conditions.  |
 WORD<0-256>  |
 Specifies the community as an alphanumeric string value with a string length from 0–256 characters. Enter this value in one of the following formats:
