Use this procedure to move a vIST Controller node pair from one DvR domain to another.
For vIST to work properly, both Controller nodes must be in the same domain.
  1. Disable IS-IS on each vIST peer Controller node, to remove the node from the SPB network.
    no router isis enable
  2. Disable DvR on each Controller node:
    no dvr controller
    Caution
    Caution
    Disabling DvR on a DvR Controller destroys the domain ID and all dynamic content learned within the DvR domain. However, the switch retains the VLAN specific configuration which you can view using the command show running-config.
  3. Configure each node as a DvR Controller node, with the new domain ID. Ensure that you configure both nodes as Controller nodes and with the same domain ID.
    dvr controller <1–255>
  4. Enable IS-IS on each vIST peer Controller node, to add back the node to the SPB network.
    router isis enable
Consider two vIST peer Controller nodes Switch1 (IP address 51.51.51.3) and Switch2 (51.51.51.4) that belong to a DvR domain (with domain ID 4), that you need to move to another domain (with domain ID 5).
View a summary of Controller configuration on each node:
Switch1:1(config)#show dvr
                    DVR Summary Info
Domain ID                      : 4
Domain ISID                    : 16678220
Backbone ISID                  : 16678216
Role                           : Controller
My SYS ID                      : 00:bb:00:00:81:21
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
InjectDefaultRouteDisable(GRT) : Disabled
VRRP on DVR I-SIDs             : Disabled
VRRP Priority                  : 100
VRRP Election                  :
Switch2:1(config)#show dvr
                    DVR Summary Info
Domain ID                      : 4
Role                           : Controller
My SYS ID                      : 00:bb:00:00:82:22
VRRP Priority                  : 100
VRRP Election                  :
Disable IS-IS globally on each Controller node:
Switch1:1>en
Switch1:1>conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch1:1(config)#router isis
Switch1:1(config-isis)#no router isis enable
Switch1:1(config-isis)#exit
Switch1:1(config)#
Switch2:1>en
Switch2:1>conf t
Switch2:1(config)#router isis
Switch2:1(config-isis)#no router isis enable
Switch1:1(config)#
Disable DvR on each node:
Switch1:1(config)#no dvr controller
Switch2:1(config)#no dvr Controller
Configure each node as a DvR Controller, with domain ID 5.
Switch1:1(config)#dvr controller 5
Switch2:1(config)#dvr controller 5
Enable IS-IS globally on each Controller node.
Switch1:1(config-isis)#router isis enable
Switch1:1(config)#
Switch2:1(config-isis)#router isis enable
Switch2:1(config-isis)#exit
Switch2:1(config)#
View a summary of Controller configuration on each node.
                    DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678221
Role                           : Controller
VRRP Priority                  : 100
VRRP Election                  :
                    DVR Summary Info
Domain ID                      : 5
Role                           : Controller
VRRP Priority                  : 100
VRRP Election                  :
View the vIST configuration on each of the Controller nodes.
Switch1:1>show virtual-ist
                                    IST Info
PEER-IP              VLAN     ENABLE   IST
ADDRESS              ID       IST      STATUS
51.51.51.2           4002     true     up
NEGOTIATED                                    MASTER/
DIALECT      IST STATE                        SLAVE
NONE         up                               Master
Switch2:1>show virtual-ist
                                    IST Info
51.51.51.1           4002     true     up
NEGOTIATED                                    MASTER/
NONE         up                               Slave
