This section provides CLI procedures for Unicast Reverse Path Forwarding configuration.
Exception: not supported on VSP 8600 Series and XA1400 Series.
To configure Unicast Reverse Path Forwarding on a port or VLAN, you are required to enable the urpf-mode boot flag. If you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
Use the following procedure to enable the urpf-mode boot flag. By default, urpf-mode is disabled.
Enable the urpf-mode boot flag:
Switch:1> enable Switch:1# configure terminal Switch:1(config)# boot config flags urpf-mode The new setting requires a reboot to take effect! The configuration will be saved and rebooted. Are you sure you want to re-boot the switch (y/n)? y
View the status of the urpf-boot flag:
Flag support can vary across hardware models.
Switch:1#show boot config flags flags advanced-feature-bandwidth-reservation low flags block-snmp false flags debug-config false flags debugmode false flags dvr-leaf-mode false flags enhancedsecure-mode false flags factorydefaults false flags flow-control-mode true flags ftpd true flags ha-cpu true flags hsecure false flags ipv6-egress-filter true flags ipv6-mode false flags linerate-directed-broadcast false flags logging true flags nni-mstp false flags reboot true flags rlogind false flags savetostandby true flags spanning-tree-mode mstp flags spbm-config-mode true flags sshd true flags syslog-rfc5424-format true flags telnetd true flags tftpd true flags trace-logging false flags urpf-mode true flags verify-config true flags vrf-scaling true flags vxlan-gw-full-interworking-mode false
Use the following procedure to view the status of the uRPF configuration on a port.
- You must enable the urpf-mode boot flag.
When you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
 You must log on to the GigabitEthernet Interface Configuration mode in CLI.
You must configure unicast reverse path forwarding on a port.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 1/10Verify the configuration on the port:
Switch:1(config-if)# show ip interface gigabitethernet
                                         Brouter Port Ip
PORT VRF   IP_ADDRESS    NET_MASK      BROADCAST REASM   ADVERTISE DIRECT  RPC     RPCMODE
NUM  NAME                                        MAXSIZE WHEN_DOWN BCAST
1/1  Glob~ 192.0.2.3     255.255.255.0 ones      1500    disable   disable disable exist-only
1/10 spbo~ 198.51.100.4  255.255.255.0 ones      1500    disable   disable disable exist-only
PORT  VRF
NUM   NAME
1/1   GlobalRouter
1/10  spboip
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 4/16Verify the configuration on the port:
Switch:1(config-if)#show ipv6 interface gigabitethernet
                                             Port Ipv6 Interface
IFINDX BROUTER PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX           ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
192    4/16    e4:5d:52:3c:65:02 enable  down  ETHER 1500 2   30000       1000        disable  disable  disable  existonly
                               Port Ipv6 Address
IPV6 ADDRESS                            BROUTER      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:ffff/64                   4/16          UNICAST MANUAL    INACCESSIBLE INF      INF
2001:db8:0:0:e65d:52ff:fe3c:6502/64          4/16          UNICAST LINKLAYER INACCESSIBLE INF      INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 10 Total Num of Address Entries displayed.
Use the following procedure to view the status of the uRPF configuration on a VLAN.
 - You must log on to the VLAN Interface Configuration mode in CLI.
Important
You must assign a valid IP address to the selected port.
 You must configure unicast reverse path forwarding on a VLAN.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface vlan 2Verify the configuration on the VLAN:
Switch:1(config-if)# show interfaces vlan ip
                                                   Vlan Ip
VLAN VRF    IP            NET              BCASTADDR REASM   ADVERTISE DIRECTED  RPC     RPCMODE     RMON
ID   NAME   ADDRESS       MASK             FORMAT    MAXSIZE WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9     255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1102 Globa~ 198.51.100.1  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1133 iir3   192.0.2.10    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1500 spboip 192.0.2.11    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1590 spboip 198.51.100.2  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
4057 Globa~ 192.0.2.12    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF
ID   NAME
1050 GlobalRouter
1102 GlobalRouter
1133 iir3
1500 spboip
1590 spboip
4057 GlobalRouter
Switch:1(config-if)# show ipv6 interface vlan
                                             Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
3170   1122 2c:f4:c5:dc:b4:89 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3174   1126 2c:f4:c5:dc:b4:8b enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3185   1137 2c:f4:c5:dc:b4:90 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:1                      V-1122       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489          V-1122       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1126       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b          V-1126       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1137       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490          V-1137       UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
