Create graphs of chassis statistics to generate a visual representation
of your data.
- In the Device Physical
View, select the chassis.
 - In the navigation pane,
expand the  folders.
 - Click Chassis.
 - On the Graph Chassis
tab, select the tab with the data you want to graph:
System
SNMP
IP
ICMP In
ICMP Out
TCP
UDP
 - Select the statistic
you want to graph.
 - Select the graph type:
line chart
area chart
bar chart
pie chart
