You must understand MAC addresses assignment if you perform one of the following actions:
Define static Address Resolution Protocol (ARP) entries for IP addresses in the switch
Use a network analyzer to decode network traffic
Each chassis is assigned a base number of MAC addresses with a number reserved for ports and other internal purposes, and the remainder assigned to routable VLANs. The following table identifies the numbers provided by product.
                 Product  |
                 Base assignment  |
                 Reserved  |
                 Assigned to routable VLANs  |
                 VSP 4450 Series  |
                 256  |
                 First 128  |
                 remaining 128  |
                 VSP 4900 Series, VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series  |
                 1,024  |
                 First 256  |
                 remaining 768  |
                 VSP 8600 Series  |
                 4,096  |
                 First 1,024  |
                 remaining 3,072  |
                 XA1400 Series  |
                 1,024  |
                 First 8  |
                 remaining 1,016  |
Virtual MAC addresses are the addresses assigned to VLANs. The system assigns a virtual MAC address to a VLAN when it creates the VLAN. The MAC address for a VLAN IP address is the virtual MAC address assigned to the VLAN.
