Undock and dock tabs
Perform this procedure to undock a tab. You can undock tabs to have more than one tab visible at a time.
- In the navigation pane, select a tab.
 - In the menu bar, select and drag a tab to undock it.
 - In the top right corner of the tab, select pages to dock the tab.
