The following table details the standard MIBs that the switch supports.
 Standard MIB name  |
 Institute of Electrical and Electronics Engineers/Request for Comments (IEEE/RFC)  |
 File name  |
 STDMIB2— Link Aggregation Control Protocol (LACP) (802.3ad)  |
 802.3ad  |
 ieee802-lag.mib  |
 STDMIB3—Exensible Authentication Protocol Over Local Area Networks (EAPoL) (802.1x)  |
 802.1x  |
 ieee8021x.mib  |
 STDMIB4—Internet Assigned Numbers Authority (IANA) Interface Type  |
 iana_if_type.mib  |
 STDMIB5—Structure of Management Information (SMI)  |
 RFC1155  |
 rfc1155.mib  |
 STDMIB6—Simple Network Management Protocol (SNMP)  |
 RFC1157  |
 rfc1157.mib  |
 STDMIB7—MIB for network management of Transfer Control Protocol/Internet Protocol (TCP/IP) based Internet MIB2  |
 RFC1213  |
 rfc1213.mib  |
 STDMIB8—A convention for defining traps for use with SNMP  |
 RFC1215  |
 rfc1215.mib  |
 STDMIB10—Definitions of Managed Objects for Bridges  |
 RFC1493  |
 rfc1493.mib  |
 STDMIB11—Evolution of the Interface Groups for MIB2  |
 RFC2863  |
 rfc2863.mib  |
 STDMIB12—Definitions of Managed Objects for the Ethernet-like Interface Types  |
 RFC1643  |
 rfc1643.mib  |
 STDMIB15—Remote Network Monitoring (RMON)  |
 RFC2819  |
 rfc2819.mib  |
 STDMIB17—Management Information Base of the Simple Network Management Protocol version 2 (SNMPv2)  |
 RFC1907  |
 rfc1907.mib  |
 STDMIB21—Interfaces Group MIB using SMIv2  |
 RFC2233  |
 rfc2233.mib  |
 STDMIB26b—Message Processing and Dispatching for the SNMP  |
 RFC2572  |
 rfc2572.mib  |
 STDMIB26c—SNMP Applications  |
 RFC2573  |
 rfc2573.mib  |
 STDMIB26d—User-based Security Model (USM) for version 3 of the SNMP  |
 RFC2574  |
 rfc2574.mib  |
 STDMIB26e—View-based Access Control Model (VACM) for the SNMP  |
 RFC2575  |
 rfc2575.mib  |
 STDMIB26f —Coexistence between Version 1, Version 2, and Version 3 of the Internet-standard Network Management Framework  |
 RFC2576  |
 rfc2576.mib  |
 STDMIB29—Definitions of Managed Objects for the Virtual Router Redundancy Protocol  |
 RFC2787  |
 rfc2787.mib  |
 STDMIB31—Textual Conventions for Internet Network Addresses  |
 RFC2851  |
 rfc2851.mib  |
 STDMIB32—The Interface Group MIB  |
 RFC2863  |
 rfc2863.mib  |
 STDMIB33—Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations  |
 RFC2925  |
 rfc2925.mib  |
 STDMIB35—Internet Group Management Protocol MIB  |
 RFC2933  |
 rfc2933.mib  |
 STDMIB36—Protocol Independent Multicast MIB for IPv4  |
 RFC2934  |
 rfc2934.mib  |
 STDMIB38—SNMPv3 These Request For Comments (RFC) make some previously named RFCs obsolete  |
 RFC3411, RFC3412, RFC3413, RFC3414, RFC3415  |
 rfc2572.mib, rfc2573.mib, rfc2574.mib, rfc2575.mib  |
 STDMIB39—Entity Sensor Management Information Base  |
 RFC3433  |
 STDMIB40—The Advanced Encryption Standard (AES) Cipher Algorithm in the SNMP User-based Security Model  |
 RFC3826  |
 rfc3826.mib  |
 STDMIB41—Management Information Base for the Transmission Control protocol (TCP)  |
 RFC4022  |
 rfc4022.mib  |
 STDMIB43—Management Information Base for the User Datagram Protocol (UDP)  |
 RFC4113  |
 rfc4113.mib  |
 Q-BRIDGE-MIB —Management Information Base for managing Virtual Bridged LANs  |
 RFC4363  |
 q-bridge.mib  |
 LLDP-EXT-MED-MIB — LLDP-MED  |
 ANSI/TIA-1057  |
 lldpExtMed.mib  |
